Device model (e.g. 2020 iPad Air 4th Gen): M1 Pro MacBook Pro
Version of operating system (e.g. macOS 14.4.1): Sequoia 15.3.1
Version of djay (e.g. 5.1.2): 5.2.9
Hardware/controllers used (e.g. Reloop Mixon 8 Pro): Pioneer DDJ FLX-4
Summary of the issue:
I have a track that is 160bpm. Whenever I drag it into DJay or load it from the playlist I put it in in my Apple Music library, it reads it as 140bpm. I keep changing it in the “Edit BPM” pane in the straight BPM section to 160, but it immediately changes back to 140, or whatever it thinks is right.
How to reproduce the issue:
Reproducing it may be hard as it requires you to find a track that it is analyzing wrong. The one I am using is currently unreleased. I have a video of the issue occurring that I can send if necessary.
Hi @c20c20, thanks for the details about your setup and the issue. Yes, please share your video by uploading it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Thanks for the video @c20c20 - this is very helpful. I have not been able to replicate this, so I’m going to pass it onto our engineering team for review. I’ll report back when I have news.
Thank you! If you’d like, I can private message you the link to the song. I can’t share it here publicly as it’s an edit of a friend’s unreleased song. Maybe you’ll be able to replicate it that way.
Sounds good @c20c20. Yes, please upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the song in a DM to me. Thanks!
Hi again @c20c20, we suspect this might have something to do with your BPM analysis range. Could you please check what your BPM analysis range is set to (Under Preferences → Library → BPM Analysis → Range)? Thanks!
Hi @c20c20, are you still encountering this issue? If so, could you please share your djay Media Library and Metadata folders so we can try to reproduce it?
Hi, sorry for late response. I’ve been busy (setting up a small radio show actually!). I realized this is an issue that only occurs once, when you first add the song to the playlist and try to change it. On the second attempt, it (seems to) always work. So it’s not a serious issue. Thank you for checking in again! I appreciate your dedication to this community.
