Hi, I’m trying to map my controller (mixon 4) to the neural mix Funktions.
I would love to use the eq knobs to do that, but then I run into the problem that the middle position is 50% volume and that makes the transition always difficult…
I would love to have an option so I can set the range for the midi message.
In my case I don’t want to use the whole travel of the eq knob as otherwise a neutral eq makes the neuramix volume always jump to 50% and I would prefer that neutral eq (middle position) is max neuramix and min eq is min neuramix. In order to achieve that I would need to be able to limit the midi range in the midi mapping.
Cheers
