I’m developing a custom motorized turntable controller for djay Pro (ios) and would like to understand the capabilities of your MIDI implementation.
The controller uses a high-resolution rotary encoder that tracks the absolute platter position and speed. My goal is to achieve accurate scratching and pitch control similar to a motorized DJ platter.
Could you please clarify:
Does djay Pro support custom USB MIDI controllers with high-resolution platter/jog wheel data for scratching?
Can a custom controller send absolute-position platter data, or does djay Pro only support relative encoder messages?
Are there any recommendations for implementing a custom jog wheel/platter for the best scratching performance?
Does djay Pro support HID controllers for custom hardware projects, or is MIDI the only supported option?
Are there any technical documents or guidelines available for custom controller development?
Hi @Polyura, I’ve confirmed the following with our engineering team.
Yes, as long as it is MIDI class-compliant.
Currently, motorized controllers cannot be user mapped. The required interactions are unfortunately too complex. You can mimic something using the absolute rotary mappings but it will not behave like a native implementation.
Map three jog commands, then tune the feel:
A. Scratch (no touch detection) for non-touch platters, orScratch (CC) for touch-sensitive ones.
B. Pitch Bend (CC) for nudging.
C. Adjust Speed and Reaction (smooth = cleaner on slow moves; responsive = tighter) until it feels natural.
D. Mapping jog wheels | Algoriddim Support
MIDI only. HID protocol is not supported for custom hardware.
There’s no public SDK or MIDI implementation spec for custom hardware — the MIDI mapping section of the user manual is the only reference. Mapping a MIDI device | Algoriddim Support
If a custom MIDI controller sends high-resolution absolute platter position data from a continuously rotating motorized platter, will Scratch (no touch detection) use the platter position directly for real-time scratching?
Hi @Polyura, it will roughly work, but the data will still be processed as if it was regular non-motorized jog wheel. It’s not a 100% raw input right to the playback speed.
Just to clarify:If my custom controller sends high-resolution platter position data over USB MIDI, will moving the platter backward cause djay Pro to play the track backward in real time for scratching?Or will djay Pro treat it only as a jog wheel nudge/bend command?Thank you!
I’ve started developing a portable scratch trainer/controller designed specifically for practicing scratching with djay Pro.
The idea is to build a compact device that can be connected to djay Pro and have:
a motorized 7” or 10” vinyl platter;
a platter mechanism inspired by the Technics SL-1200;
a physical feel as close as possible to a Technics turntable;
Hot Cue buttons and other basic DJ controls;
USB MIDI connectivity to djay Pro.
The main goal is to make the platter feel as natural as possible for scratching, while keeping the whole device small and portable.
I’m trying to understand the recommended MIDI implementation for a custom motorized scratch platter in djay Pro.
Should a motorized platter use Relative Rotary or Rotary (Absolute)?
More specifically, does djay interpret Relative Rotary messages purely as incremental movement, or can the timing/frequency of incoming MIDI messages affect the amount of movement?
The goal is to have a true 1:1 relationship between physical platter rotation and scratch position. For example, if the platter is rotated exactly 360°, the resulting scratch movement should correspond to the same amount of track movement regardless of whether the platter was rotated slowly or quickly.
If this is the desired behavior, what MIDI message format, rotary mode, and update rate should be used?
Also, does djay Pro have a specific MIDI implementation for motorized platters, or are custom motorized platters expected to use the standard Rotary/Scratch MIDI mapping?
Is there a recommended MIDI implementation or protocol for developers building a custom motorized scratch controller?
Hi again @Polyura, I heard back from engineering. As mentioned above, motorized platters are not user mappable right now. So, any recommendations on MIDI format won’t be of any use to you.
