Customisable velocity of play head when rotating Jog Wheels.
Is there a way that this could be set in preferences, perhaps with a slider, so you could adjust the velocity of the play head when you rotate the jogs - ie faster or slower? On my controller I would love the playhead to cover more ground when I rotate the jogs in Vinyl mode.
Also:
I have loved seeing the evolution of Djay since I first started using it in 2011.
Infact I just sold my Serato controller and bought the Reloop BeatPad 2 and Mixtour to use with my iPad as my main and backup rig.
Loving it! (except for lack of this feature :slight_smile: Keep up the good work.
Richard.
Hi Lukas thanks for your reply. I did some reading of the documentation for djay last night and saw that. Will give it a go. Thanks for your speedy response.
Richard
Hi Richard,
Thank you for your mail and your nice feedback :slight_smile:
You can change the velocity of jogwheels in the midi mapping window, but you are correct, there is no knob to change the velocity on the fly.
I added your request internally to our user request list and wanted to thank you for getting in touch.
