Customise time on Cue point
I place a cue Point at the first vocal section and also the last, so I know where I can mix out with no vocal clash. I would love it if I could have the first Cue show second into tHe track, but the second cue show seconds remain. So I guess in summary, individually set seconds gone or remain per cue point.
Did you know there is a start and end cue point besides the colored ones?
No, where do I find that?
I hav3 found with the new upgrade you can name the cue points so instead of it saying 3:56, I can rename it to say 0:45.
They are white, well half white/grey
This is how I am tagging tracks, the vocal starts after 1:07 and the last vocal is at 4:52, and that is 49 seconds from the end which means I have 49 seconds of instrumental to mix out.
You should try using Start/End cue points instead.
Once you use these Automix can use those to mix like you do
Thank you. That’s looks very useful.
:+1:,
Also, Instead you can use those colored ones for chorus that repeat throughout the song.
It’s good for bouncing around that track to shorten or lengthen a song.
Here’s an example. Older djay, but same principle.
