Please consider sharing a short video or screenshots to help clarify your suggestion
YOUR SUGGESTION:
djay 5.6.1 added support connecting DJM-A9 use Pro DJ Link, but even when four decks are connected to the A9, sometimes only decks 1 and 4, or decks 2 and 3, are used.
When using only two decks, the unused decks are displayed in four-deck mode, and the PC screen is not used effectively.
In 2-deck mode, the deck numbers are usually 1 and 2, is it possible for you to provide a function that allows you to specify any deck number in 2-deck mode?
For example, deck no 1 and 4.
Thanks for the suggestion! I’ll share this with the devs for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
Also, we have a similar suggestion topic over here:
Hey guys, I’ve been using djay pro for just under a year now with my ns4fx and when I was on vdj and serato I started using 4 decks.
The 4 deck layout on djay pro is literally a sensory overload. I’d really appreciate less waveforms (2 active is enough) and 2 seek bar for the passive decks.
Hi @Edward_Campbell, welcome to the Community! I’ve merged your new topic with this existing one as I think they are closely related. Please use the blue Vote button at the top left of this page. Thanks!
Lovely that PRO DJ Link is supported now. When using the DJM-A9 however the default channels with 2 players connected are 2 and 3. Would be cool if djay could only display deck 2 and 3 in that case.
This is possible in the usb connected mode because it allows the user to select the channel when connecting the players to djay.
