I love using my launchpad as a midi controller for djay but the inability to customize colors for different sections of the board makes it hard to use in the dark. Is there a driver for controlling the colors or a patch to allow use with Automap? That would be swell. Thanks a bunch!
Did you get anywhere with this? I’ve previously created a MIDI map for the LaunchPad in Traktor. But djay pro 2 doesn’t seem to be able to do the same…
Hey
I know I’m a bit late with this, but I have created a Midi Mapping for Launchpad Pro.
Here is the Dropbox - Link
Installation-Guide:
Download
Open Finder
Go to Users > Your User > Music > Djay Pro > Midi Mapping
Lay down the downloaded Midi Mapping
Connect Launchpad
Press Shift
select the Orange Part in the first row
Start djay pro
go to midi > configure Launchpad Pro Standalone Port
Select Midi Configuration Launchpad Pro Standalone Port Midi Mapping
restart Djaypro and leave your Launchpad as it is
Before Opening djay pro the next session, repeat step 5 to 7
deck 1 and 2 are identic just test a bit and you gonna see what is what.
Use the top for navigating through your library.
The 8 pads, which are unmarked are volume faders of a and b the master and the headphone level
the section in the lowest !Pad! row between the two green pads is the crossfader.
If someone requests I can create a picture that describes every single button.
