I have a new suggestion to improve our library in DJPro AI.
Today we all have many different folders and playlists that we use to always find the best next track.
But today DJPro only allows you to choose which columns you want to see in all folders and playlists, and in what order you want to see them.
I’m sure it would be interesting to be able to customize each folder or playlist with the columns and order you want. This would undoubtedly make our work even easier and make us like DJPro AI even more.
E.g: a folder or playlist that I only have with house music, I wouldn’t need to display the Genre column in that folder or playlist.
Now, a folder that I have with music from the 80s, I wouldn’t need to display the Release Date column, but it would be important to have the Genre column.
Thanks for the suggestion @brunolima. I’ll share this with the devs for consideration.
Yes please team, I’ve got a few playlists I work through in numeric order and others I run by BPM and matching key. Resetting the columns each time is manageable, but it would be amazing if it was one less thing to worry about while I’m spinning.
Thanks for the additional feedback @Owe_Marley. I’ll share this with the devs.
Hi guys, just checking if there’s an estimated timeline for when this will be built.
No stress at all, just thought I’d check in as this will make set building a lot smoother being able to search the library and drop tracks into specific spots without reworking playlists.
Thanks for checking in @Owe_Marley. We don’t have any updates or timelines to share for this suggestion.
thank you slak_jaw please please can we add this to next build
You’re welcome @Owe_Marley
