Is it possible to change the track loaded when I choose Scatch Tools in the “Eject - Load Next - Double - Scratch Tools” pop up window? I saw that the Pop-up window will be implemented in Djay pro for iPad and it would be really cool to be able to customize the track that is loaded. Cheers!
Back again with the same question. Is it possible to change the track loaded when I choose Scatch Tools in the “Eject - Load Next - Double - Scratch Tools” pop up window?
Exactly, now it is the DJ Qbert’s track. Would be cool to be able to change tracks.
thank you for your post. If I am getting this right, you want to change the Scratch Tools option to another track?
Cheers,Lukas E.
