Is there a bug with the quantize function, I find it not accurate.
Hi there and welcome to the forum. Can you be a little more specific as to what exactly you are finding a problem?
I find with quantize on and using cue points, its not on point , its a bit off, could be me since I am used to the way it works ion Serato DJ
Did you check how you configured Quantize (which beat value is it set to? 1, 1/2, 1/4?) and whether your beat grids are correct?
What would be your preferred beat setting for quantize as l too sometimes find it a bit off when using it…
I like using 1, its the same I use in Serato DJ, however it just seems off.
Hi @Junior_Pops,
Are there any additional variables or details that you could provide us with so that we can better understand your use case?
Additionally, what version of djay are you using and on what platform?
