DDJ-1000
I have a DDJ-1000 if I want to use the beat fx, for example the echo effect it only works on the mst channel. If i choice the channel where the song is playing from it doesn’t work. I think i don’t have te right prefrences on dj pro 2. Can sombody help me with this problem?
I have the ddj 1000 as well and I experience the same issue. I’m pretty sure it has nothing to do with djay pro 2 preferences its just that the onboard fx do not work when the channel selector is switched over to any of the channels other than mst. I hope pioneer will let the fx be use on all channels other than mst while using other software aside from rekord box one day. Meanwhile I managed to map djay pro 2 fx to turn on and off when the channel selector is assigned to a specific channel.
There are so many open topics :wink:
https://community.algoriddim.com/algoriddim/topics/dj1000-beat-fx-on-individual-channels
https://community.algoriddim.com/algoriddim/topics/beat-fx-channels-not-working-pioneer-ddj-1000
just saying.
Pls use the search function. =)
Stay safe.
How did you do that to a specific channel ?
