So I recently bought a DDJ 1000srt and when i pluged it in some of the functions didnt work so i had remap it but when i started a track the volume indecators did not show any light, but when i tryed it in serato the lights woked. is therre a fix to this or do i have to down load some drive for it.
@Sam_Sattah unfortunately, it’s not currently possible to manually MIDI map with Volume Meter LEDs with djay’s MIDI Learn tool. This needs to be done by Algoriddim within the default mapping. I recommend you try reloading the default mapping to see if the LEDs work on it. If so, duplicate the default mapping and add your new MIDI controls to it.
Hey @Slak_Jaw in regards to the srt, is there a beat counter like VDJ has on their software? Or is the beat counter the lines within the waveforms?
@Sam_Sattah Go into the Settings>MIDI Devices and load the built-in mapping instead of your edited version.
