DDJ-200 split audio issue
  • Device model *DDJ-200 :
  • Version of operating system WIN11:
  • Version of djay (e.g. 5.2.10276.0):
  • Hardware/controllers used (djay pro):
**Your question:**Hi guys, I have a problem with connecting sound separately to headphones and speakers. I’m using the splitter cable that came with the board. I can’t separate the sound for pre-cueing. My settings are on split as per all the instructions and I’m out of ideas. Has anyone else dealt with a similar problem?
Hi @Martin_Vetro,
Sorry to hear you’re having these issues!
So that I can better assist you, could you please answer the following questions:
  1. What version of djay are you using?
  2. Is djay recognizing the DDJ-200 when you connect it to the PC?
  3. Can you send us a screenshot of your audio routing settings within the djay app including Main Output and Pre-Cueing?
