Ddj 400 con Djay Pro para windows
Hola, saben si podre usar la DDJ 400 con DJAY PRO para Windows?
We can assure you we are working on all our software.
The DDJ 400 is so far not supported by our Windows version but I added your message to our user request list.
Thank you.
Cheers,Lukas E.
Dont use the Windows version it SUCKS!!!
they did the last update in July2018…
