I bought al DDJ 400 and tried tot connect it wiht my Ipad + DJayPro. Ipad can’t find the DDJ400 (‘no devices found’) in de MIDI / Supported DJ Controllers menu. I already updated IOS and the firmware for the DDJ 400. What can be the problem?
Hi DJ O,
Please note that djay for iOS our latest version of djay is supporting the DDJ 400.
Did you check it out?
Are you using a hub? If so is it a powered hub ?
Yes, i use a powered hub (lightning to USB)
Hello Lukas, Yes I checked it out. Still no connection…
