Hi everyone thinking about getting the DDJ-FLX due to likeness of jog wheels with CDJs but want to check if it works with DJ pro 2 and tidal?
Hey, you’re in luck, DDJ-FLX6 is listed as supported for iOS and macOS. In general, when checking about hardware compatibility, there is this very helpful page: DJ Controllers, DJ Mixers and other DJ Accessories | Algoriddim. Be sure to scroll down and click to select all platforms you’re using (iOS, macOS, Windows and Android) to see which controllers are compatible with which platform.
Hi @G0ggs,
Thanks for asking this in the Community.
djjoejoe is right, this controller is natively supported on Mac. But since this controller came out after we moved to djay PRO AI it was not added to djay PRO 2 for Mac. You could benefit from the free upgrade to djay PRO AI to use this controller on your Mac. To do so, follow these instructions: https://help.algoriddim.com/hc/en-us/articles/360017483679-I-previously-purchased-an-older-version-of-djay-djay-Pro-2-Am-I-eligible-for-an-upgrade-discount-
If your macOS version is not compatible with djay PRO AI, please reach out to us directly through support@algoriddim.com We’ll find a solution for you.
Cheers, G
