- Version of djay 5.5
- Hardware/controllers used DDJ-Flx10
Hello, what is this feature? Can‘t find it
It’s Mac only feature. Windows probably as well but I only have Mac.
Ok, thanks.
What does this feature do?
Besides, I find it a little disappointing that IOS only users (I only use my iPad with Djaypro) cannot use recent features of the software
Yeah I understand that. When you press and hold down any parameter button the screens will show if I’m hotcue mode what hotcues you have, if in fx mode on pads what fx you have etc. pretty cool feature.
I believe one library works with pc also. So you should be ok there.
I think because the screens follow HID protocol and apparently won’t work with IOS.
