- Device model: M1 - 12.9 - iPad Pro 5th Gen
- Version of operating system: ios 18
- Version of djay: 5.2.4
- Hardware/controllers : Pioneer DDJ-FLX10
Summary of the issue:
In addition to JOG WHEEL DISPLAYs, I ask that you look into the CROSSFADER issue on the iOS.
It seems that the option of changing the crossfader curve (in options) no longer works.
The DEFAULT option sounds like CUT.
How to reproduce the issue:
Plug in your FLX10. Go to the SETTINGS → SOUND → CROSSFADER CURVE → DEFAULT
The crossfader only acknowledges 3 positions.
