DDJ-FLX10 two channel settings
  • Device model (e.g. 2020 iPad Air 4th Gen): MacBook Pro M4, 24Gb/1Tb 2024
  • Version of operating system (e.g. macOS 14.4.1): Tahoe 26.3
  • Version of djay (e.g. 5.1.2):5.6.2
  • Hardware/controllers used (e.g. Reloop Mixon 8 Pro): DDJ-FLX10
  • Hardware firmware version (e.g. 1.0.1): 1.0.3
  • Playing with dual laptop (1 djay one serato). GUI in Two Decks cannot select 3/4
  1. Connected via USB A(or B) assigned 3/4 channels to djay (1/2 assigned to different laptop running Serato, Driver setting: Other Software)
C) EXPECTED RESULTS:
  • Able to control 3/4 channel via Two Deck
D) ACTUAL RESULTS:
  • only 1/2 can be controlled in Two Deck, cannot find setting to select 3/4. You can only control 3/4 in Four Deck GUI view. Or obvious… I’m not clever enough to find that setting for it :slight_smile:
Low priority, as I moved serato to 3/4 and got 1/2 for djay
Hi @djmario_ro, welcome to the Community! This is currently expected behaviour with djay. In 2 Deck Mode djay can only control Deck 1/2.
However, we have an existing suggestion topic to enable 2 Deck Mode for Decks 3/4 if you’d like to upvote it:
