Hi @djchase, the Smart Fader button isn’t locked down anymore. Also, you can easily MIDI map an unused button to the Crossfader FX toggle yourself:
- Go to Dashboard > Settings > MIDI Devices and tap your DDJ-FLX4.
- Press an unused button or SHIFT+ the desired button on the FLX4
- Set the Target to Mixer and the Action to Crossfader FX Toggle.
- Tap Save and give it a new name so you keep the original mapping as a backup.
If Crossfader FX Toggle doesn’t show up in that list, or it saves but the button does nothing, let me know exactly what you see and I’ll dig into it. I hope that helps!
If you’ve never used the MIDI Learn tool in djay before, please refer to the section linked below from the user manual.
