Hello! Can anyone tell me what I need to do in order to use the DDJ-FLX6 just like a turntable? I want to be able to cue the track by rewinding, fast forwarding etc. on the jog wheel and actually THROW in the beat instead of pressing play/pause. Also, is there a power button? Any suggestions are much appreciated Thank you everyone!
Hi @Algo,
You can press SHIFT and the โJog-Cutterโ button (when the Jog-Cutter button is off). This should enable/disable the scratching mode.
You can find out more about the Jog-Scratch function here:
Hope I could help.
Very helpful, thanks
