DDJ-GRV6 Jog Wheel sensitive
Hello, I hope you’re doing well.
I would like to ask if there is any option to adjust the jog wheel sensitivity.
I’ve noticed that the DDJ-GRV6 feels extremely sensitive when using Djay Pro, especially compared to Rekordbox or other DJ software.
Is there a way to fine-tune or adjust this behavior?
Thank you in advance.
Hi @Raver_Man, the only way to adjust this is within the MIDI Learn tool of djay. You could try making an edit of the built-in MIDI mapping and adjusting the Speed and Reaction in the Advance Control Configuration for each jog wheel. This will likely require some trial and error to achieve the sensitivity you’re looking for.
If you’re unfamiliar with MIDI mapping in djay, please refer to the linked FAQ below. The process is actually easier than you might first think. I hope that helps!
@Raver_Man let us know how you get on and if successful, please do share the numbers you went with.
Not many other GRV6 owners around so I’m always on the lookout for cool mods to make and settings to change to make life better :smiley:
