DDJ GRV6 - Level/Depth Bug
  • Device model M1 Mac Pro:
  • Version of operating system macOS Sonoma 14.6.1:
  • Version of djay 5.3.3:
  • Hardware/controllers used DDJ GRV6:
ISSUE:
The level/depth knob location is not respected.
How to reproduce the issue:
Turn the knob to 0%.
Activate Beat FX.
FX are active and audio reflects greater than 0% FX (likely at 50% or more).
This did not happen prior to the software update.
Hi @gizmo, thanks for the details about your setup and the issue - this is very helpful! To ensure that I properly communicate this to our engineering team so they can try to replicate it, can you please capture and share a short video of the issue? Thanks!
Hi again @gizmo, our hardware team was not able to reproduce the issue based on your description. As requested above, can you please try to capture a short video of this? Thanks!
Notice the knob is placed at 0% yet the effect does not respect knob placement @slack_jaw.
Thanks for the video @gizmo. I’ve passed it onto our hardware team for further review.
Hi again @gizmo, please navigate to the djay Settings>General>Song Loading an ensure that Reset EQ, FX, tempo is un-checked. Thanks!
Done.
Though, one should be able to keep that setting checked without impacting knob intensity.
So did that solve your issue @gizmo?
Not necessarily. I’ve noticed if the knob is at 0% or 100%, there are still issues. If the knob is slightly more or less than each extreme, there are no issues.
Hi @gizmo, can you please share another video with the issue shown at these extremes and the Reset EQ, FX, tempo is un-checked? Thanks!
This seems to be an issue when first starting DJay. If you play with the knob a little then attempt to reproduct afterwards, there is no issue.
It solely happens when first loading DJay, having the knob at the extremes and activating the FX.
I have a workaround for this, just need to remember before the set begins. :slight_smile:
