Ddj rb windows pre cueing
So bought the ddj rb thinking I could use it with djay pro and i cant select which channel i would like to hear in the headphones. The master works fine. I am not the only one by looks of it. Level meters also dont seem to work correctly. Will there be an update any time soon that will sort this out?
Hi guys
about the RB, please note that as stated on our Hardware site:
✧ Pre-cueing via the controller is not supported, but headphones can be used via the PC’s built-in audio output.
Terry, did you install the designated driver of the SR 2 you can find it here:
https://www.pioneerdj.com/en/support/…
unfortunatley you only find this out after youve purchased the controller because the website says its supported
