DDJ-SB3 Transport Buttons behaving strangely with autodetected config
I fire up DJay Pro, plug in my DDJ-SB3, click “Yes” to use the new device, and the following functions act strangely:
Skip Backward: jumps forward and backward randomly, may be caused by pressing button rapidly.
Skip Duration +: Does not work
Skip Duration -: Does not work
Reverse: Does not work
Forward: Does not work
Skip Forward: Skips forward as expected.
On the native mapping I have Beat Jump mode enabled (ie HOT CUE is flashing), and the codes seem to be mapped write.
Happens on all decks.
Hi Matthew,
we are working on a native mapping for the SB 3 on Windows.
Stay tuned, we will let you know when there are news.
EDIT:
Sorry for the misunderstanding, the SB 3 is natively mapped for djay Pro for Windows. If you are experiencing problems with the mapping please contact us right away via support@algoriddim.com.
Thank you and sorry for the mix up.
Note: All functions work in Serato.
Upon further testing, the Skip Backward function going forward only happens while the track is playing.
Do you know when this will be ready? I can’t really buy DJay Pro until it works with my hardware
