I recently switched from Serato to Djay Pro, using Pioneer DDJ-SR as controller.
My issues:
- it’s not possible to simply slide the pitch slider on the DDJ-SR when sync button is active. I first have to quickly move the slider up and down to make it active/respond
- when loading a track, I have to quickly turn the gain button left/right to kind of reset the gain.
In preferences:
- Reset (EQ, effects, controls) => OFF
- Reset Sync Mode => ON
- Auto Gain => OFF
- Audio Limiter => OFF
Are these settings ok?
Working on MacBook Pro, all the latest software, firmware and updates.
Thank you,
Jan
