I recently bought the DDJ-SR2 today. I am using it with Djay Pro software. All functions work except the sound. The sound will not play out the speakers, also with the precueing. I need help, I don’t want to use Serato.
Hi Nefretiri,
Did you install the designated driver of the SR 2?
You can download the driver directly via:
https://www.pioneerdj.com/en/support/software/controller/ddj-sr2/
