using ddj-sx on the windows demo version. can only get audio coming out of channel 1. channel 2 LEDs are on but not routing to the master out. cue buttons light up but don’t do what they are supposed to do. i.e. they don’t cue the audio just bypasses to the master.
settings are ddj-sx as controller and audio device. device is exclusive, external mixer
is there a hidden menu to route the audio to each channel. also trim does’t make a difference . highest signal i am getting is just above the low knob on the LEDS.
run serato as well so i know its an an issue with my controller. can you help pls.
thank you
