Your question:
Hi!
I just came across this wonderful app but I am having problem outputing the sound to a stereo system. I can only hear the songs playing on my iPhone speakers. Everything but the headphone cue buttons works fine.
what is the problem? Thank you I am using it on my iPhone 11 Pro 256GB
my controller is a pioneer DDJ SX3 and I am using the latest djay
I’m not so sure if SX3 is supported in iOS…
Hi @DJChambinhoBH, welcome to the Community! Please note that the DDJ-SX3 is not compatible with djay on iOS. It is only supported on macOS and Windows because this device is not fully USB Class Compliant. I hope that helps!
I too am looking to use DJay pro on an iPad with a DDJ-sx3. I understand it doesn’t show up in iOS because it’s not class compliant. But I do want to ask.. is it possible to develop a solution? Would it have to come from Alpha Theta? …and would it be wishful thinking to ask for this kind of support from them?
Hi @djsilenttom, welcome to the Community! Yes, this would have to come from the hardware manufacturer - possibly via a firmware update. However, given the age of this device, I suspect this is probably unlikely.
