When I have a filter adjusted on the DDJ-WeGO and all a new song on deck, auto play on or autoplay off, the software resets the filters to the center even though on the DJ Controller they are not. Very frustrating and prevents me from using this product functionally. Perhaps there is an easy solution.
Glad you found that! If you have any other questions, just let us know.
I spoke too soon, under the preferences, song loading I needed to uncheck the Song Loading Reset button, all is fixed. Thanks
