DDJ - WeGo2 Doesn't Charge My iPhone! Help?!?
My WeGo2 Controller Does not charge my iPhone 5S (A1530) while djaying! Can anyone help and advice? Since iOS drains battery like CRAZY!!!
The 3rd. version of the wego does charge the i-stuff.
I’m sorry, but the Pioneer Wego 2 is not capable of charging your iPhone while being used.
No, the iPad won’t be charged either.
Will it be able to charge iPad?
So what the point in this if you can only Dj as long as you have battery power??? Is there no way of connecting both the charger and the wego?
