DDJ WeGo4 Jog Fx
Hello. I would like to know if it is possible to modify the mapping of DDj WeGO 4 in order to use the jog to adjust the intensity of the effects when they are activated. Thanks in advance for support.
Hi Igor,
Can you tell us which djay version and device you are using exactly?
Thank you in advance.
Cheers
Hi Igor,
in djay Pro for Mac you can change an existing mapping in the Midi Learn feature (top menu bar “MIDI” -> Configure Pioneer DDJ WeGo 4).
In the window, send a midi action of the Jogwheel by using it and you can adjust the sensitivity of the wheel.
Hope this is helping
Hi! I use the latest version of Djay Pro on Macbook Pro.
