DDJ1000 SRT Isolator EQ Mode not working
Need some help.
I am using Djay Pro Ai on my MacBook Pro M1.
With DDJ1000 SRT.
For some reason isolator mode isn’t working at EQ type settings, even if it is “turned on” in the settings. Am I doing something wrong ?
Thx
EQ modes in the software will have no effect when using external mixers.
I actually found the fix. I found what was the problem and fixed it and now it works.
I can switch in external mode in the settings in between classic and isolator.
Glad you figure it out. Thanks for letting us know.
