YOUR QUESTION:
- How can I activate the Fx for Deck 2 with the Omnis Duo as Controller. I only can activate the Fx and can use the Parameter for Deck 1. Where can I change to Deck 2 or Master?
YOUR QUESTION:
Hi @T_Boyle, When creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency.
Hardware Firmware Version:
Please confirm that you are running the latest v1.23 firmware from AlphaTheta: https://support.pioneerdj.com/hc/en-us/articles/26559347114649-OMNIS-DUO-Firmware
Since this sounds repeatable, can you please capture and share a short screen recording of the issue to help clarify what’s happening? Thanks!
Hi again @T_Boyle, I did some more digging and found the following:
The Omnis Duo has no buttons or UI elements to switch the FX unit between Deck 1 or Deck 2. In djay we have mapped SHIFT + Beat FX to toggle between “Select FX Deck 1” and “Select FX Deck 2”. Please try this and confirm if that resolves your issue. Thanks!
Thank you, that answers my question and it works. Is there a documentation of the MIDI-Mapping for the Omnis-Duo. Most mappings are easy to understand, but not all.
You’re welcome. We do not have any MIDI Mapping documentation for this device.
