Deejay Pro 2.09 - Bug Sampler
I detected a Sampler problem, either from the Midi controller or from the keyboard. I’ve mapped the Toogle Sampler button to need to view or remove the view while I’m working. If by chance you press the “Toogle Sampler” mapped button together with a RIGHT Sampler button (Kik 1, Snare 1 …), the RIGHT Sampler does not work anymore, it becomes silent. While the LEFT one works ahead without problems.
Hi CorradJ,
thank you for your post.
Can you please send us an exemplary video of the described issue, that would be very helpful.
Thank you in advance.
Cheers,Lukas E.
Thanks, I sent you the video by e-mail.
My configuration is Macbook Pro 2017 15 "MacOS Mojave
Hello, after 2 update the Bug that I reported was not even taken into consideration? It is always present.
2.0.12 Ancora niente sempre lo stesso BUG
