Is there a way to remove multiple tracks at once or select all of them to delete from the main Music folder in My Library playlists? It seems like you can only delete individually
The quickest way would be with swipe the tracks in the list. Swipe from right to left, and a long enough swipe will just remove the track from the list altogether
Hi @SteNight, I’ve added your question here and also added your request to our internal list for future consideration. Adding your post here will ensure that you’re notified with any updates.
