Deleting Files and Folders - Android
Eu também estou com o mesmo problema, há alguma previsão de correção? Isso realmente me gera bastante dor de cabeça
Hi @Bryan_Marvila, welcome to the Community! Please include an English translation of your post. Thanks!
Hi again @Jaroslaw_Szkudlarek, sorry for the delayed reply. Our engineering team was able to reproduce this and they are investigating further. I will share more news here when I have it. Thanks!
Great, thank you, better late than never:) I hope that the error will be removed quickly, I keep my fingers crossed and thank you again
You’re welcome @Jaroslaw_Szkudlarek
I just downloaded update 5.5.2 and haven’t checked yet but haven’t found any description for it. is that normal? But thank you anyway I’ll check what it fixes and what it spoils;) Have a nice weekend
So version 5.5.2 again brought bad key lock gaming, there is no question of crosfader with Neural effects because it is crazy about the worst changes compared to 5.5.1 . Not significant changes include no pitch fader display on the home screen, no blue illumination change of lock notes, no BMP on the home screen. To sum up, this deterioration compared to V. 5.5.1 of the sound from the key lock where on 5.5.1 it was already ok. The check was made on Android 15 Lenovo M11 4 gb RAM and Reloop beatpad 2 controller with firmware 018. Well, gentlemen, you didn’t show off, which is a shame
Hi @Jaroslaw_Szkudlarek,
  1. So version 5.5.2 again brought bad key lock gaming.
    a. Can you please clarify what you mean here? I spoke with engineering and they did not make any changes to Key Lock between 5.5.1 and 5.5.2
  2. There is no question of crossfader with Neural effects because it is crazy about the worst changes compared to 5.5.1
  3. Not significant changes include no pitch fader display on the home screen
  4. No blue illumination change of lock notes
    a. The Blue Key Lock icon is now working as expected on 5.5.2. Please check again. I tested this on my Android device and it works as expected.
  5. No BMP on the home screen.
A post was merged into an existing topic: Tempo Sliders and BPM missing after update - Android
Unfortunately, translators poorly translate technical terms! The point is that cross fader with effects is not possible because you hang the Djay app. I wrote that now the notes are illuminating. No speed slider drawing, no BMP window. That Djay stops working and shows a dialog box “wait or close apps” meaning Djay crashes
Thank you @Jaroslaw_Szkudlarek,
Our engineering team was able to reproduce the audio distortion issue with Key Lock and Sync enabled. There are looking into this further. In the meantime, we have halted the 5.5.2 rollout in the Play Store, so you might be able to re-download the 5.5.1 version.
I have moved your other comments and screenshots to an existing bug report topic.
