Deleting the app and re installing
  • Device model (e.g. 2024 iPad Air 5th Gen):
  • Version of operating system (IOS 17.5.1):
  • Hardware/controllers used (Rane One & Denon Prime Go):
Hi, just curious as to what will I lose if I decided to delete the app and then re install it,
Will all my Cue points, Playlists and settings including midi mappings still be saved?
In this, he explains how to save all the info you may need.
Hi @maurizio_T,
Thanks for sharing your question.
djay handles data a bit differently on other platforms when it comes to deletion.
However, on iOS, I can confirm that nothing is saved after uninstalling and reinstalling the app.
Have a nice day!
