- Device model : iPad Pro M1
- Version of operating system: iOS
- Version of djay: 5.1.7
- Hardware/controllers used: Denon DJ x1850
**Your question: Will this mixer receive BPM from my iPad when connected on the USB input?
Hi @Christo_S, the X1850 Prime currently does not receive BPM information from djay. Thanks.
Thanks for the answer!
Does the Xone PX5 receives BPM from iOS?
You’re welcome @Christo_S. The Xone PX5 FX Unit requires MIDI clock, which is currently not supported by djay.
I have passed the “BPM receive for the X1850” request onto the dev team for consideration though to see if we can support this in a future update.
The PX5 states that can receive midi clock from usb.
So Djay in general cannot send midi clock? If not, it would be a great addition!
Correct. Sending MIDI Clock is currently not supported by djay. However, I recommend that you hold on a little bit as I believe there will be some news regarding the X1850 coming soon
