Hey there I use a Reloop Elite hooked up to an old iPad Pro in DVS with two Technics 1200 and Serato control vinyls. I’m pretty happy with this dvs system but I’d like to create a more “portable” set for small gigs. Now, I’ve found a Denon DN-SC 2000 for cheap. My question is: will it work as a track controller if connected to the “USB HUB” ports of the Reloop Elite? (the ports are named “RP-8000 / CONTROLLER”)
Hi @Kermodee-jay, you can connect a MIDI controller to the Reloop Elite USB hub, while having the Elite connected to an iPad and the MIDI messages do pass to and from the iPad. Also, the Denon DN-SC2000 is officially supported on djay for iOS (see below). We don’t have access to the specific setup you describe above, but in theory it should work. I hope that helps!
