Denon LC6000 + Djay - not more than a children toy ?
I have tried it 6 month ago and I tried it just again but there is so much missing to consider it as a professional setup. Is it only me and everybody else is happy or is no one using it this way ?
I dont want to go in further detail but only make a backspin and you know what I mean. :frowning:
You should go into a little more detail. I don’t have an LC6000 myself, so I can’t try it out. But what exactly do you mean, what does not work? A backspin may not work, but that alone cannot be decisive.
Oh yes, it can. If something is listed on second place as recommended DJ Gear then it should work perfect. There may be some other LC6000 owner which may have an opinion on this as well.
Hi @Aquadics,
Would you mind sharing some or all of the missing components that you would like to see integrated into djay with this hardware?
Hi @NathanielAlgo,
Thanks for your reply. As soon as I will have some time in the next days I will try to provide you the missing information. I have the great opportunity to compare between the combination DJay + LC6000 and SC6000 + LC6000.
For now, have a great day !!!
I have two LC6000’s and find them to be very good. They do need a little bit of adjustment for DJay Pro, but that’s normal with most set ups, unless you’re buying everything from one company.
As far as a backspin, yes, that could definitely be improved upon. The jogs are not as loose as I would like myself, but I’m used to coming from vinyl or free wheeling jogs. I did have to go in to the settings and adjust the sensitivity to max, but since then I’ve had no problems with them.
Hi @Archiesbald,
not that I depend on backspins but only to know that it behaves like it behaves with Djay makes me sad.
There should not be a sensitivity setting to adjust it. The song should change the position related to the jog wheel. Currently as soon as you are not touching the jog wheel anymore the software is falling back in Pitch Bend mode.
Algoriddim could fix it by adding some additional logic. I never got this behaviour with any other software/hardware combination. (Traktor Pro, Engine OS)
I will try to provide a video to make it more understandable and hopefully this will motivate Algoriddim to improve this in an update.
Hi @Aquadics,
Thank you for the additional info and yes a video would be fantastic if you are able to provide one.
Thanks so much again!
@NathanielAlgo I will try to provide something during the week.
The weekend was too hot and shiny :slight_smile:
Ok, as I have mentioned there are different things I would like to mention so let’s start first with a easy one :slight_smile:
If I am changing the Loop size (no matter if the loop is currenty active or not) I would expect to see the current loop size in the wheel display like I would see it if I use a LC6000 connected to a SC6000.
I see this really useful but this is currently not supported from Djay.
Hi @NathanielAlgo, now you got a description from a first issue which should be improved. Is this something the software team will work on and fix ?
You know, I am not a big fan of waisting my time, making movies and reporting issues to get nothing out at the end because Product Manager, are not motivated to follow user suggestions of there user base. So I will await if there will be notable changes before I move on to reporting the next one. :slight_smile:
Hi @NathanielAlgo, Is this something which will be improved or is it not worth to report anything in the forum ?
**UPDATE 12.07.2022 (after 6 days with no answer)
I see it is pointless to report anything if there is not any feedback or intention to make it better. I wish all of you good luck with a product which is only trying to fake professionally. The title of this thread is confirmed. Djay is not more than a beginner app.
Sure, everyone has their own requirements and needs and everyone works differently. But because your requirements are not met in combination with your hardware, the application is not automatically just a toy.
Don’t get me wrong, I also find it annoying when something like this doesn’t work and also when you don’t get any feedback from support. I also always find things that should be done differently or better. But which software is not like that? In this area, it is always difficult to really consider and map all needs equally with one product. And in sum, DJay Pro offers so many features that it goes far beyond a toy. And last but not least, for many it is also without alternative, because it is the only app with such a range of functions that you can use on and with the iPad. And that doesn’t just apply to DJing itself, but also to preparation. Listening to new tracks and preparing them (cue points), creating playlists, sorting … everything on the same device, always at your fingertips. In any case, DJing with a laptop is no longer an attractive option for me.
Sure it’s not a children toy but you may get that my intention was to make the title more provocative. :slight_smile:
What me really bugs is that there was already actively a request from Algoriddim to get more information but with no follow up after days.
But still, it is not about my requirements. It’s about the fact that the support of LC6000 does not go as far as we would expected. There are some really annoying differences compared to the usage of an LC6000 with a SC6000 and I would expect that it works the same way and they could be easily improved. For now it looks Pioneer and Denon DJ gear is proposed as top notch equipment as a marketing gag.
And you are right that DJay is offering functionality like iCloud support you would expect from any modern app in 2022, but other DJ apps does not. And on the opposite site there is a lot of AI which will bring you no where in your professional DJ carrier :slight_smile:
Of course Djay’s DVS support could be another story and a new era but time will show.
Hi @Aquadics,
Thank you for your additional information regarding this topic thread and your continued feedback as for support.
I will make sure to pass your detailed loop feature request along to our dev team for further review.
I will also let our dev team know of your observations regarding the LC6000 and the SC6000.
Please note that your patience is greatly appreciated as we answer large amounts of community threads, emails, social media posts and more on the daily.
Have a nice day!
Yes aquatics I know first hand what ur on about but I have the solution for anyone reading this
U need to go into midi settings, scratch (cc17), show advanced control option,
Speed 58% reaction 104%
Now hopefully that’s a bit more like serato integration
