Denon LC6000 stuck in "loop size" mode
hello I’m new to Djay software. I seem to be unable to save a loop using the denon lc6000 controller. I can di it fine with a mouse on the screen.
I’m aware that there are two pages of loop controls for the denon controller and mine seems to be stuck in the second page that adjusts the size of the loop along the 8 pads. I’m not able to save loops.
auto loop also always records 1 beat loop, even though I set it to another value, such as 8 beats.
is there a menu setting I need to adjust?
many thanks.
Anyone experienced this?
Thanks.
Hi @Emergingstates, welcome to the Community! when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency.
Hardware Firmware Version:
Since this sounds repeatable, can you please capture and share a short video of the issue to help clarify what’s happening? Thanks!
Hi thanks for replying! I will try and reproduce the next time I have a chance.
Many thanks.
You’re welcome @Emergingstates
