Yes, that’s amazing news!! Big props to Lukas and the algoriddim team!
Looking for Djay Pro support for the MCX8000 too. I’m primarily a Serato user but digging the tight Spotify integration especially for use at home before buying new music. I’ve posted same request in the Denon forum. here is a link to it http://denondjforum.com/t/djay-pro-su…
Looks like something with be coming up in the future. Don’t quote me though http://denondjforum.com/t/djay-pro-su…
Let’s go people, please support the 8000
The screen doesn’t work right?
brauhardtmichael@gmail.com - can you share the mapping with me too ?
dj-lucas@live.com - i would love to get a copy of that map
what about for windows?
I would buy the controller if screens worked.
@Lukas - are you looking to add the screens support?
Hello to all. But does the new version 1.4.4 also support screens or is it just a mapping?
When will the Djay Pro IPad Pro app support the mcx8000 natively?
Tomas it doesn’t work with my iPad Pro.
add support screen MCX8000, today I tried the Trial version and I must say that it works very well, We hope in a next update, I have nothing against Virtual Dj, but if it works with them the visual waveform and library, I do not see why not it must be there for Mcx. Let’s wait
Guys maybe I expressed myself badly, I want the support to be added to the screens, at the moment the screens show only the writing Denon MCX8000. I apologize for the misunderstanding.
Anders, is there any plan to support the displays?
Dis you ever try mapping yourself?
Are you using or have you used this mapping on the mcx8000 successfully?
Any better luck operating the controls?
Hello guy’s I’ve only one working channel. For 2/3/4 it’s ok for control (play, cue…) but no sound ! how can fix that ?
thanks !!
