Denon prime 2 support?
Hi @Landrews,
Thanks for asking this question in the Algoriddim Community.
Unfortunately, the Denon Prime 2 is not currently natively supported on djay.
However, you can map any MIDI controller yourself using our MIDI-Learn feature. How to do this? You can find a full description here, depending on the system you are using:
-Windows
-Mac
-iOS
djay Pro makes this a really straightforward process. You can have a look at a full updated list of all our natively supported Controllers here.
It would be great if the rest of the Community would vote/comment on this DJ Controller request. :ballot_box:
If you have any further questions, please feel free to reach out again.
Cheers, G
any update on the prime 2? i just bought and am looking to see if it works on this program.
I recently bought the prime 2, but i’m not really a fan of engine’s software. I was wondering if it’s supported or not or possible to map it out.
Hi @George_Cruz,
At this time, the Denon Prime 2 is not natively supported in djay, however, please take a look at Guillermo’s original reply from March 2022 for more info on this topic.
Have a nice day!
+1 for Denon Prime 2 native support, the Prime 4 is natively supported and that’s a near-identical unit just the 4-channel version.
