Denon Prime 4
Will Denon Prime 4 be natively supported?
Please say yes!
Hi! The Prime software Is it really so bad compared with Djay IOS ?
I’m actually using Reloop Mixon 4 with iPad Pro with last version of Djay and I’m evaluating moving to Prime 4, but I have seen a lot of software problems reports.
The Prime 4 hardware looks amazing (way better than mixon 4), but software side is key to allow a smooth set.
What are your experience with it ?
Fernando.
Hi Maria,
Thank you for your post.
I added your request to our user request list and pushed the topic.
This would be so awesome!! The Engine Prime Software is not that great right now, you could just put the cover back on the original display and rest the iPad right in front of it. Won’t be able to use USB but that’s okay… Hope this gets implemented!
Whoops! Sorry for the accidental double post
somebody made a “temporary” mapping , works great except for the “squiggly” jog wheels, any way to fix? other than that, the mapping is great
http://community.algoriddim.com/algor…
Any news on this being official?
It’s not that bad, a lot of it has to do with the preparation software, which they are trying to work on
Thank you!
