Denon Prime Go Jogwheels Mapping
Yes that would be ideal although I’m a bit used to the size of the screen of my iPad Air so the Denon screen would be a bit smaller I guess
Hi @salsaweb, please note that the hardware manufacturer needs to unlock access to their screens before we can add support for them in djay. We have reached out to the manufacturer requesting this, but it will help to expedite the process if djay users could also contact the manufacturer and express their interest in having screens unlocked for Algoriddim djay. Every voice helps. Thanks for your support!
hey ! has anyone trying to use it from the iphone ? can you import that map using the iphone app? thanks !! just checking in if anyone has tried out.
Hi @Camilo_Duarte, please note that the Denon Prime Go is now natively supported on iOS with the latest version of djay. There is no need to import a MIDI Mapping. There will be a built-in mapping when you connect your iPhone.
Hey ! yea i just got the cable i was looking usb-B to lighting, but sadly have to pay ! just to try it on. i am not a pro. so just not justify the price. :frowning:
Hi @Camilo_Duarte, there’s a free trial of djay.
