Denon Prime Go on Android
how to combine denon go prime and Android pad 7 pro from Xiaomi?? Has anyone had any experience?? Can you tell me, please? I installed djay pro on my tablet, but for some reason it doesn’t work.
Hi @IK_KZ, welcome to the Community! Please note that the Denon Prime Go is not supported on Android. For our full list of supported hardware on Android, please refer to the linked list below:
Bonjour
Je possède une Lenovo tab m11
Et j’aimerais connecter ma Denon prime go en midi dessus avec djaypro
Comment dois je faire ?
Hello,
I have a Lenovo Tab M11.
And I’d like to connect my Denon Prime Go to MIDI with djaypro.
How do I do this?
Hi @adrien_poncin, please use search before creating new topics. I have merged your new topic with this existing one. This hardware is not supported on Android. Thanks!
Can you use an Android device while using a Prime Go and if so what adaptor do you need. Thanks
Hi @DANG3RUST, welcome to the Community! The Denon Prime Go is not supported on Android. Here’s the list of supported hardware on Android.
