Denon Prime Go+ question
YOUR QUESTION:
  1. Hi Guys, I’m just wondering if anyone out there that has the Denon Prime Go + and is using it with Djay Pro with an IPad or iPhone,
  2. My question is that I have the original Prime Go and it has one hiccup with it in that when you are using the EQ or Filter dials, turning the dials from the 12 0clock position requires at least 1mm of travel for it to make a difference to the command it is trying to do.
  3. If anyone with this set up could please chime in to tell me if it has been fixed with the Prime Go + I would really appreciate that.
