Device not found in master output
I can’t find my XDJ Aero as output device in preferences/master menu. I wonder if it is related to the new 1.3.1 version? The midi control from the device just work fine.
please check if the right driver is installed.
Have you lately updated to El Capitan?
If that is the case, are you able to map the Pre Cuing output to the device, is it only the Master Out which is not mappable?
Thank you in advance.
Hi Vivien Duflot,
this is great knows. Always glad if i can help.
You’re absolutely right ! It was indeed related to the migration to El Capitan. I updated the driver and now it works fine.
Many thanks for your quick and efficient answer !
Cheers.
