Dials like Gain or Filter don't match position in iOS interface with Traktor Kontrol S2Mk3
I’m using a Traktor Kontrol S2 Mk 3 with iPad Pro and Pro Version of Djay Pro. It works pretty well but one annoying issue is that the position of the rotary dials doesn’t get mirrored in the app. Then, if you turn the dial it jumps to the right place. However - then once you’ve e.g moved the Gain control and load a new song they get out of sync again. Is there any solution to this?
Thanks! Mike
Hi Mike,
Thanks for asking about this. Have you tried turning off the “Reset EQ” function in the djay for iOS settings? You’ll find this option under "General"in the Settings Menu.
Let us know if the issue persists.
Best regards,
Guillermo
